I finally did. I'am not disappointed. It looks and works as good or better than I thought. I figure I'll make this a guide as to what I did, step by step. (maybe it might become a D.I.Y. piece, who knows). Before I begin, I just wanted to mention a couple things. 1- This is not for the faint of heart, or for the inexperienced. 2- If you do attempt this or any project like this, make sure you have every conceivable part you are going to require beforehand. 3- Do your research. Find out what parts are required to be replaced to accomodate a swap or change. 4- Make sure you have the proper tools to do something like this. This will reduce aggravation and down time. I 'am am going to post this in two parts. First, the removal process. Then, the conversion and install. I condensed the pics to only what is needed to be seen to explain as I go along;
1 - I started by raising and properly supporting my vehicle by the rear crossmember. Then I removed my rear tires;
(Tip: I sprayed all applicable bolts with Liquid wrench the day before)
2- Next, remove the drums. If you happen to strip that pain in the ^$## machine screw, with a small drill bit you can drill it out.
3- After removing the drum, remove the center hub cap. With an 1 1/4 socket, loosen the hub retaining nut. USe a breaker bar, because this nut is torqued to 180 ft/lbs. Remove the hub. If your drum is frozen on, remove the hub and drum together, than tap the hub off the drum. The hub is re-usable. Do not throw away.
4- Remove the front and back brake shoe retaining springs.
5 - Remove as an assembly. There is a retaining clip behind the backing plate that holds the brake cable in place. Remove it first. Then, disconnect your parking brake cable.
6 - Disconnect and remove the brake hose. (The replacement hose has a special fitting to accomodate the caliper) Discard. Save any and all clips for the brake hose. Remove the four bolts from the backing plate. Remove the backing plate.
7 - What remains is the spindle (knuckle). Spray all the bolts on the suspension parts. And start loosening them. Usually, the long bolt is sometimes a problem. From soaking everything in lube, it came out without much difficulty..
8 - Remove all the bolts, and then the spindle (knuckle).
Here is the difference between the two knuckles: right - drum. Left - disk.
I bought a rear suspension off an 03 with ABS for about $200, in a Staten Island junkyard. The knuckles, brand new from the dealer, $300. Online, best price $228. And thats for one, not two.
9 - Re-install new knuckle with lots of never-seize. I replace the long bolt with a new one and torqued to spec's.
Here ends part I. I'll need a day or so for part 2...........
