1 - 20 of 23 Posts
Calf...Ankles...Cankles!!
well according to that, with my xd, weighing 2900lbs, and 160 (crank) hp, it says i should be running a 15.19 at 89.08. it has to go by CHP because if i put in 3000lbs and 140hp, it says 16.06 @ 84, which i am 100% sure is incorrect :D
Noob (play gunbound?)
Crank HP eh? I guess it does not take into account reaction times. But Crank HP would be quite inaccurate because the parasitic loss is highly variable from car to car (even among the same make and model).
But the calculator seems consistent with Crank HP. (if you compensate for reaction time).
reaction time has absolutely nothing to do with ET's. the clock does not start until you do. you can sit at the tree for 30 seconds trying to get your rpms exactly where you want them, run your race and still run a 15 sec 1/4.
its not a yelling situation that needs caps...i bolded it to make sure you saw it clearly :)
:D thanks. At least now I won't look like a complete idiot when I do talk to ppl at the track (if I ever go).
This is one cool tool though.
Wow such response. So how would you compensate for the innacuracies?
the fact that theres no input for gearing, the calculators cant be taken truly seriousely. so dont be let down if it claims alot faster time then you actually run.
Super Moderator
@ 2700lbs with me in the car and assuming 160bhp = 14.83 @ 91.23. which is right because i know if i had gotten out to the track one more time i'd have done better. especially if i went to a better track.
the world ends dec21 2012
i dont know how much my car weighs but lets say its on the heavy side at 2900 lbs and a very conservative crank horsepower guess of 180 i do a 14.60 @ 92.65 hmm who knows if its right
Crazy Imaginative
still pretty cool.
now if only i had 2000 hp...
Here goes being really anal about something mode:
Horsepower only tells half the story, peoples.
What about torque?
Seriously, even if you had, like, 9000hp, it ain't going to be worth nothin' unless you have enough torque to be able to feasibly use it. (that's why hondas are made fun of here... sure, there is hp, BUT WHERE'S THE TORQUE?)
Now, the calc needs to take into account tire condition, wind resistance, gearing, torque at the gears, when turbos spool (if you do happen to use turbos), and so many other variables.
I know I'm being an anal about this. But still, pretty cool.
Wow your XD is almost 300 pounds heavier than my XD my curb weight is just over 2600 in stock trim
Sent from my QMV7A using Tapatalk
The XD is NOT in the 2600 pound range. Hyundai claimed the weight was just over 2600, but they actually republished the weight of the older, smaller, lighter J2.
In 2001 Caranddriver magazine tested an '01 XD, base model, manual, no options. On their scale, it weighed 2886.
Some people claim 26xx pounds. But anyone that has ACTUALLY had their XD on a scale knows that the 26xx figure was BS.
1 - 20 of 23 Posts
