Some of you may be thinking this is alittle crazy, but for a budget upgrade, this is well worth the money. You will need three components for this upgrade:
1: Two RAYBESTOS Part # 980385. These are from the 2004 Kia Spectra LX. Cost is 27.79 a rotor. RockAuto.com has these.
2. Front Calipers from a XG350. Year 2003-2005. These years were the only ones to have the dual piston setup on the car. These will bolt directly to the knuckle assembly. You can get these from car-part.com, cost is 30-50 for a pair at a local salvage yard..
3. Brake Pads. Tirerack carries Hawk brakepads for the XG350, and will run you about 50-60 dollars.
I run this setup on my Elantra with no issues on the stock master cylinder. There is no brake fad and the stopping power is much nicer now. And for under $200 you have a new brake setup!
