1 - 2 of 2 Posts
My 2003 GLS with A/T ( 129,000 miles) will not shift into reverse. I made certain the fluid is at the correct level. The backup lights do not come on when the gear lever is placed to reverse. The transmission shifts into all "Drive" gears as it should.
I have disconnected the battery twice and the transmission worked as it should for a week or more then it stopped shifting into reverse again two weeks ago.
There is no CEL. I also changed out almost four quarts of fluid around two months ago.
What if anything am I overlooking? I hope the transmission does not need to be replaced.
I appreciate any information provided.
1 - 2 of 2 Posts
