1 - 2 of 2 Posts
I've been having a slight cooling issue over the last few days. For 7 years the temp has stayed in the same spot. Now, it rises slightly and then drops back to normal. Has never actually reached the red section of the guage. Fans are both working, overflow and radiator have coolant in them and the heat works. If I see the temp going a bit high and turn the heat on the temp will go down a bit.
I'm thinking of a coolant flush since it's never had one. Also looking at replacing the thermostat. My issues is that I've been on sites that show it at the top and others that show it by the bottom hose. Can anyone definitively tell me where the thermostat is?
If on top I assume I could change it after the flush. If on bottom I'd have to change them at the same time, correct?
Thanks
1 - 2 of 2 Posts
