what size tires do you have? with stock tires I run close to 75mph in 5th.
Well, maybe he'll get a lower rpm depding on the ration of the 6th?the 6spd is just closer ratio. the 6th gear i believe is actually shorter than the elantra, so you wouldnt be accomplishing what he wants.
i suspect nissan started running 6spd gear boxes so they could use less powerful engines, but still get them moving as fast as one with a bigger engine.
I have the same type of drive. I65, 865, 465 to keystone and two stoplights later I'm at work. That's why I went with teh 205/55's instead of the "correct height" 205/50 16's long ago. I keep in mind that an indicated 65 is closer to 70 ground speed and back off a little and get (got, having new issues)great gas mileage on my non-CVVT Beta.It looks like OD tires for me. I figured I would not be able to find a taller 5th gear, but it was worth a try. I drive all most all interstate, so I was looking for better gas mileage in any way I could get it. Especially since I am keeping this until it dies, which hopefully will be 12 more years.
Thanks for the input!
what are you talking about?^ SMACK....please sit down and be quite.
