Does the Accord Intake Fit the XD Elantra?
In a word YES!! Most, if not ALL the 94-97 Accord intakes will fit our cars. Be it either the 1,2,3piece versions Generic Ebay, AOS, AEM etc etc. The designers of these intakes all had a 94-97 Accord to work from. See example below
What price can I expect to pay?
Prices for the Accord intakes range from Ebay ones $30-$40 to APC/AEM $60-100 maybe more
What version is the best?
Personal preferance is the two piece intake. But any of the above listed will do. There are just more fitment adjustments possible with more pieces
How easy is it to install?
Its easy!!! Installation should take you anywhere from 1/2hr to 1 hr depending on your mechanical aptitude. Some simple removals, connections and instal is basically in reverse but even easier.
Is there any cutting involved during the install?
There may involve cutting of the end of the CAI. This depends on your preference though. You should use your own discretion as to the ending location of the CAI.
You will need to bend the lip of the wheel well entry location slightly to allow for free access into that area. Some rubber padding should avoid any rattles or banging. If you cut any metal, don't forget the rust proof paint.
Any other cutting involved?
For use of the AEM intake, it was confirmed in an earlier thread that the end of the tubing inside the fender well does need to be cut off about 3" for the filter to have a nice home If your concerned about appearance, don't be YOU CAN'T SEE THE FILTER anyways
Where is the CAI routed?
The CAI is connected the the Throttle body by a provided silicone conector. It takes a few turns, goes threw the stock intake location hole behind the battery and eventually ends up in the wheel well.
Pic shows finished routing of a three piece version.
Will the intake make contact or bang into any of the other engine components?
There is a posibility of this happening. The intake MAY come into contact with the brake fluid reservoir or its tubing. To avoid this situation try readjusting the itake and its connections. If you still can't avoid contact. Wrap the Brake fluid tubing with a small rubber hose that you slit in half. This will protect it.
Do I NEED the AEM bypass valve?
USE your own discretion here. Yes, if you plan on driving threw deep puddles up to your wheel centerline or if you live in a flood prone area.
What HP can I expect to see from this Mod?
You should realistically expect anywhere from 5-10HP, This increase will give your car the added HP to help overcome that lag at around 3800RPM's
Can I combine Different versions of intakes?
Yes, its been done here. http://www.elantraxd.com/yapp/index.php?board=6;action=display;threadid=916
What size diameter is the best?
Subjective but the best size intake Dia. for any 4cyl engine is 2 1/2". This is Dyno proven many times over. Any cone filter CAI in a 2 1/2" size will still provide More air than the engine can realistically use.
Can I use the 2003 Tiburon CAI?
You can use the V6 CAI, overall length might be an issue though. there would be a 6" section missing from the long section of tubing where the MAF sensor goes. And its a 3" DIA. See point above.
What about the I4 CAI?
Sure will
ADDED INFO
Is it loud?
YES
Do I need to move the battery?
NO you do not, I managed to install the accord intake without moving or cutting the battery tray. Simple adjustments of the tubing angles will take care of this.
Many props go to Fordfaster, MCM and Daille for their inovations and pioneering
Sure will
ADDED INFO
Is it loud?
YES
