I also want to add to anyone reading this and whos unsure, Clutchs for all 97-01 tiburons will work fine, as will any listed for the elantras and 2.0 GK tibs. Please don't ask this question or say you can't find _____ clutch for your car. Those clutches will work fine.
Any other members who feel like doing a similar thing about their aftermarket clutch/flywheel combo (Felix, Donnie, Ish, anyone at all) please do and I will quote and add it to the oringal post
Cypher said:OK. I think I've had this setup for much longer than anyone else so I thought I'd put my thoughts out on it.
My setup: XTD Stage 3 Clutch + 11lb Prolite Flywheel
I bought this setup back in summer of '05 and didn't get around to installing until October 1st, 2005. The whole shebang cost about $299 IIRC. Aside from the "normal" frustration that most people get when doing a clutch on these cars for the first time, the install went along fine. I had about 68-69k on my car when it was installed.
Upon first startup it was evident that the clutch pedal was much more springy. That would be the best way I could describe it. There was a little more resistance than there was with OEM but not as much as an old time cable clutch. You could tell the clutch was beefier.
The clutch disk itself was a 6puck. As anyone will tell you, driving a 6puck takes some getting used to but I didn't stall when I first drove it like I know another member did. Its normal for there to be a chatter when engaging the clutch slowly, if you get on it quick and go, its a slow engagement. Theres also a "whine", which is the best way to put it, that you'll get at times that other people with 6 pucks have experienced. This is normal.
At the time it was installed I was N/A modded. I was never able to get it to slip or to burn it. I dynoed out at 141whp which isn't alot but it held it fine and still holds fine. I have raced a whole bunch of times, 15+ runs down the 1/4 and of course other runs/spirited driving else wheres so this clutch has seen its share of abuse.
The car now has 125,XXXmiles on it and I still have this clutch installed. It still does great and still doesn't slip when I beat on it. I'd recommend this clutch to anyone who just plans on N/A and possibly spraying nitrous on it. I really have nothing but good to say about my experience with this clutch.
If you have any questions about the clutch/flywheel combo just ask away, I just wanted to put this up since its an ebay clutch and offer my thoughts to anyone else considering it.
I have had two different combos on my car, so I will share both experiences with you:
1- ACT Street Clutch Kit/Fidanza Flywheel - Cost: ~950$
I recommend this for anyone who's N/A. Stay away from this if F/I. I had this particular combo for about 20,000KM. Half of it was boosted, and the other half N/A. I was pushing about 11psi daily on the Alpine Turbo.
One day as I was doing a WOT run on the highway it slipped. Not a bit, but, very badly. It felt like it just let something loose and then from that moment on it would slip all the time in WOT over 3,000rpm in any gear. They say rated for 240wtq. I highly doubt this is the case, because i sure as hell wasn't making that much power!
But, I must say that now since I am back to N/A I chose this kit again (see next paragraphs for the intermediate kit I had), and I am very satisfied. Definitely the best combo for NA performance in my opinion because the disc is organic but holds more than stock, without the drawbacks of pucked discs (see below).
2- ACT 4 puck ceramic sprung kit/Fidanza Flywheel - Cost: ~980$
This kit was so-so. It was holding the boost well for the little while I had it when turbocharged, but I only kept the turbo for about another 8,000km so I didn't really get the chance to beat on it. However, I did not like this clutch at all. The break-in period was horrible, but that's not it. It chatters badly if you're not used to it, but a couple of days and you get to know it.
However, my biggest complaint and possibly the reason why I chose to remove it after 10,000km is the WHINE. God damn is it annoying. Every time you slip it it makes a horrible whining sound. And I'm guessing the 4 puck is worse the 6 puck from what I gather. And for those who say "I don't slip the clutch blah blah blah'', yes, you do when you take off from a dead stop, don't tell me you chirp the tires in the middle of traffic all the time, you can get a ticket for that.
However, the Fidanza flywheel hasn't caused me problems. The fact that they use the stock ring gear on it makes it safer than ebay knock-offs that might chip a tooth or a couple (I saw that happen on RDT).
All this said, I've owned both these combos, in order, and now, I'm back to the ACT street disc!
