1 - 2 of 2 Posts
Hey all
If you look at this picture. There is a plastic tab in the firewall where above is a ground wire. Remove this plastic tab and you will have another bolt hole for another ground wire. On the engine block, there's another bolt hole there as well. It's another good grounding point.
Just though I would share this. Thank you Pumba for the pic.
Later on
Teach
That and also the alternator. Get a 4 gauge wire and mount 1 end to the bracket of the alternator and the other to the battery.
1 - 2 of 2 Posts
