1 - 5 of 5 Posts
It uses the same shifter as the rest of the XD's and 2003+ 5spd Tibs
I have the TWM from the Hp.com store. Links are in my sig for that and others.
1 yes as autobot said they do make them
2 if you have a rotozip or a dremel yes it is pretty easy to install. if not its a pain
3 not sure on the warrenty part. probably not.
4. cost. the B&M and TWM are both about 120$ the tib shifter is a inch shorter than ours and runs around 30-40$.
Is there something different about the '04 that makes you need a dremmel?
Because I sure as hell didn't need one on the '03. I just used basic hand tools.
As far as warranty goes, you will be fine unless you muck up the install which is pretty easy.
1 - 5 of 5 Posts
