1 - 6 of 6 Posts
Hey guys, I've searched around and I haven't found a definite answer, and I know that you guys know a lot more about this than I do.
On my gen coupe I payed $150 for a used CNT stainless steel 3" single exit exhaust system(The whole thing only weighs like 15lbs! It's so much lighter than the stock one). The muffler touches the plastic diffuser on the genny. I've had it on there for about 4 months now, and no plastic has melted and I am planning on wrapping my diffuser in high gloss CF wrap.
Do you think that the CF wrap will melt off with the muffler touching it, or should I make a heat shield for the muffler so it won't burn off the wrap?
Like so, look at the right side above the muffler
I know this doesn't pertain to elantras, but I'm keeping it a secret from the gen community until I get the looks of the car finished up.
This also was a problem that I was thinking about on my elantra because I had my exhaust aiming up and at an angle, I was afraid that it might burn the bumper over time.
· Premium Member
The vinyl will melt in an instant if it makes contact with the exhaust tip. You can melt a hole in the vinyl with a heat gun or hair drier, exhaust will destroy it if it's making direct contact.
· lag, lag, lag, bye.
Why not just get the exhaust adjusted a little bit so it no longer touches?
Seems like making a shield would just be a bandaid fix to the problem. I would adjust or modify the hangers so that the muffler sits at least half inch away :)
Discussion Starter · #4 ·
I'll take a look again, because it was installed in front of my friends place in the dark. We played with the hangers a bit, but it wouldn't go any lower.
Maybe we missed something :(
Plus I always wanted a cool heat shield for when it spits flames :D
Yeah I would just reweld the hangers lower as snooze suggested. That would be your best fix in keeping the fart can from melting anything :)
Rather simple and quick fix too :)
1 - 6 of 6 Posts
