1 - 9 of 9 Posts
I see quite a few adds that state bolt patterns of 4x100 will fit the Elantra's with 4x114.3 patterns. Does anyone know if this is true ? Many more ads out thier for the 4x100 pattern which would make things much easier.
Also, anyone have a good site for Rota Wheels ?
scared like cheese
4x114.3 is correct. Nothing else will work. The stuff you've seen that said 4x100 might have been drilled for both 4x100 and 4x114.3 but 4x100 in a single drilling will not work at all.
Romans 8:28
Yeah... my wheels will fit 4x100 and 4x114.3 because it has 8 holes drilled in each wheel. One set of holes is closer and the other set is a little further apart. THat's probably what they mean when they say it will fit both.
*Should*
Most 8 hole wheels are 4x100 and 114.3, but I would verify that before I drop any money.
My buddy's has 8 holed 15" rota Circuit 8's. they are all 4x100 holes, but the 16" 8 holed are 100 and 114.3.
just try and get verification.
With Odin on our side...
Hey RonnieSan what lug nuts/bolts did you use on those rims? Do you have specs on them ? Or where did you get them??? I'am waiting on a similar set of rims my self...
do all Elantras have the 114.3 pattern (meaning will 2005 stock rims fit on my 2000 Elantra)?
1 - 9 of 9 Posts
