So im looking to order some Diamond Racing Steelies/Wheels. Buuuuuut i need to know a couple things before i ask for a quote, things I'm not sure about are in bold, things i do know are in regular.
So I'm wondering if anyone has ever used some wide tires like 10" and whether i they will fit into the front of the car without rubbing. Also if i get the backspacing right then that will also prevent rubbing. Im thinking of using a 5" backspacing but i might use a smaller one, maybe 3" instead, that would also help with the tires being flush with the edge of the fenders.
Width: 10"
Bolt Circle: 4x4.5"
Bolt Pattern: 4x114.3mm or 4x4.5"
Backspacing: 5"
Finish Choice: White Powdercoat
Application: Asphalt
Width: 10"
Bolt Circle: 4x4.5"
Backspacing: 5"
