This is a DIY soda can glare shield for XD
Hasn't been tested with HIDs yet
It installs nice and the price is great
Tools:
Sharpie
Razor
Dremel
Steps:
1 - Use your razor to cut off the top and bottom of the can so your left with the center of the can.
2 - Cut the center of the can down on side to make a tin sheet.
3 - Cut the measurements I laid out for you or make your own. For clean cuts score it don't try to cut.
4 - Finish and clean up edges and make adjustments with your dremel and a sanding bit.
5 - Test it out!
Please post you views on this and post your design if you alter it.
This was just a quick DIY I herd about and figured I would try making a pair but I don't have HIDs to test it out.
But I do have a head light in parts right now and spare OEM shields.
Hope it helps someone.
Tools:
Sharpie
Razor
Dremel
Steps:
5 - Test it out!
