southpawboston said:
i got my info from the published schematics, and my car was consistent with them. but i wouldn't put it past hyundai to switch out wiring colors. they did that with some of the fog light wiring on the 04's.
trunk light-- pin C11, green/black. your's doesn't have it??? how does your trunk light come on then? you can also use pin A10, green/black. that's the wire that trips the trunk open icon in the instrument cluster.
so how does the shock sensor work? did you hook up the warning circuit to the horn?
My car is an 03, produced in May of 03. Tims car also is the same wiring color wise and was produced in November of 02 (as an 03 model).
I put the blue wire from the sensor, which is the main trigger to the hood pin switch. I have not added the horn setup yet, that will be another modification at a later date. I wanted to do 1 thing at a time to see how things worked.
I mounted the relay to shut off the sensor inside the hole where the ETACS is located, and that is zip tied to a yellow loom out of the way. The instructions to the sensor recommends mounting it to plastic panels or a wiring harness, which it is zip tied to a harness nearby the center console out of the way of my hand controls. I have it set so it goes off with a decent hit anywhere on the car.
I think my trunk light (I have the sedan) is hooked up to the circuit that the trunk indicator light is at. That is the only explanation I and a dealer in Renton (Lia Hyundai) can come up with. Whether they tried to simplify things or make any changes, they never told anybody about it. :wtf:
Not only this came up, but I was talking to Jay about the block of the 2.4 liter engine (I thought it was similar to the 2 liter engine block). Noooo, Hyundai decided to use a completely different block than the 2 liter block (another one of their crazy ideas). Instead of using a block that is used for several different engines, Hyundai uses a separate block for each engine, making tuning much harder. Their engine management system seems like Microsoft Windows. Both have so many holes to fill up with updates, keeping up with them is a job in itself.
