2003 Elantra GLS 5 Speed.
Alpine Developments Supercharger kit.
Stock Ported Intake Manifold.
Stock Ported TB
Carbonman Intake heat spacer.
OBX Adjustable Cam Sprocket +8* advanced.
Intake: Custom Made FordFasteRR 3inch Hybrid Accord/Civic CAI.
Custom made Ground wire kit.
1.8L Elantra header with OEM 1.8L J2 heat shield.
Custom made 2 1/4 full exhaust.
DynoMax Super Turbo 2 1/2 inch muffler with stock tip.
Polyurethane filled FRONT motormount & NextGen Full Poly Rear Mount.
NGK BKR5E-11 Spark Plugs.
NGK Plug Wires.
Split Second ARC1 Digital Fuel tuner
MSD DIS-2 pn-6211 Digital Ignition Module.
Odyssey 15 lb Ultra Light Solid Lead Battery (680 amps).
Drivetrain:
Aimco 6 puck stage 3 clutch.
Slave cylinder Mod.
Custom made Short Shifter (cut shifter mod).
NextGeneration Polyurethane REAR motor mount.
Quick-Steel Shifter base bushings.
Quick-Steel Shifter Linkage Bushings.
Ebay Lowering springs.
Tuscani Front Strut Bar.
GT-V6 Sway Bar.
GT-V6 Front Caliper swap using 04 sonata 11 inch rotors.
Wheels/Tires:
Yokohama AVS ES100 205/55/15
12.5 lb light weigh rims Rota Slipstreams in Bronze finish.
Pioneer Head Unit.
Arospeed racing seats.
Carbon Fiber Hood with hood pins. Removed OEM hood latch.
Custom made light weight grille. (just re-painted it, looks really nice Nov 17, 04)
Removed dealer installed pin-stripes.
Removed dealer installed black molding.
Removed dealer decals fron trunk lid.
Custom painted tag plate (panited to match exterior color).
Misc:
Gutted trunk.
Removed spare tire & Jack.
Removed sound deadening material from under passenger side carpet.
Jan 2005: > Alpine Supercharger installed... work in progress..
Dec 19 2004: > Updated Exterior & Engine Bay Pics.
January 2005- MSD Ignition box installed...
Just before the MSD install...
Nov 20, 2004:
___________________________________
DYNO Sheets:
Updated Feb 1, 2005 ( Supercharged, 5-6 psi ).
Updated: Jan 18, 2005 ( Naturally Aspirated ).
__________
UPDATED ! hehe
Stock Ported TB
NGK Plug Wires.
Drivetrain:
Slave cylinder Mod.
GT-V6 Sway Bar.
Wheels/Tires:
Pioneer Head Unit.
Misc:
Gutted trunk.
Nov 20, 2004:
DYNO Sheets:
__________
UPDATED ! hehe
