1 - 4 of 4 Posts
I bought this from the dealersihp to see if it would fit a 2004. I was trying to complete the OEM Tib aluminum pedal set; however the assemblies are non-interchangeable. $10USD + shipping is all I want.
They are "interchangeable", but there is a fair bit of slack before the pedal starts pulling the cable, which causes a decrease in the range of motion for modulation, and then the floor mat has to come out in order to avert the loss of full throttle because the backside of the '03 assembly is much thicker than the '04. Also, the '04 pedal also pivots off the end of the assembly, the 2003 unit is one solid piece from cable to pedal, that also restricts range of motion. I just can't live with those compromises. I'm just going to epoxy the Tib Aluminum pedal cover to the '04 pedal.
1 - 4 of 4 Posts
