If you look at the wheel well cover in front of the drivers side front tire, you'll see the openings for the air intake box. Well, if you look through the drivers side fog light hole, you'll see the direct back of the stock intake box which is solid, no holes. What if I were to take out the fog light hole cover and cut a hole in the back of the intake box? Will it work to get more air up into the engine? Or will the air just go in the new hole and out of the stock hole and vice versa?
