So im on my way home from work the other day and This starts happening..
Im thinkin ok.. everything in that door is done with either a good crimp tool or is straight soldered together. Theres no way that would come loose right?
So i pop off the panel
yeah i know its messy. thats cause i made all the wires long enough to remove the panel and still have some slop so nothing gets pulled tight.
The wires that come up come straight from the amp in the back, i ran my own wiring so im not using the factory wires at all anymore.
i dont care what anyone says about how its not that hard to run wires from the car to the door, that was a pain in the freakin ***.. anyway
Check all the connectors and everthing looks good. i start playing music and shaking the wires, bending the solder points to the tweeter. messing with the crossover. cant make it mess up. everything is fine and in good.
Pull off the midbass driver, grab the connectors and as soon as i touch the positive terminal it cuts right out. as i wiggle the connector its obviously losing connection. a quick inspection shows everything fine.. its on tight and its metal on metal.. Then as i start to remove it i see the problem. The wire has oxidized, which wouldnt really be a huge deal, but there so much that its all over the connection itself and gunking it up with crud, looks like what you would see on an old batter terminal, white and green nasty buildup. I took some pics, but sadly you cant really see it that much.
On the first pic, you can see some of the stuff powdered off and is sitting on the lower left of the connector. in the second you can definitely see that its crusy.
since i have the thing at an angle you can kinda see that its lookin gross..
I decided i didnt want to reuse that thin wire anyway, so i just cut that whole section of wire off and ran a new 16g line for the speaker. Who needs connectors anyway? Once i solder the wire straight to the terminals that crap is never gonna give me issues again lol.
I wrapped the wire around the terminal.
Then tossed some solder over it on the front and the back. I was pretty happy with how clean it looks, not like anyone will ever see it once its installed anyway though.
Then i did the hot line and made sure there was solder on the front and back, i didnt want the possibility of it getting caught on anything or pulling etc.
pic is kinda ****ty but you get the point..
Problem solved. Now i can go back to blastin some floyd
