No, it's lab tested.... so it's not even close to a road test.By the way, the numbers that Hyundai, and other companies come up with, are not the absolute most that the car will get. The number is a conservative estimate based on tests in 2 different locations in the USA, each one with a different climate and elevation. When you're outside of those two test areas and scenarios, you can get better or worse mileage.
tHE front O2 is more important as it reads Air/Fuel mixture and adjusts the engine from there. If it's reading "leaner" than what it really is, than the engine will dump more fuel to make it even out to the a/f ratio it wants at that specific load/speed. The rear is only moderately impacting, but if it senses the cat is not working enough, it will enrichen the fuel to get the cat hotter to work more effectively. When the rear O2 doesn;'t shoe enough difference, the engine will try to compensate for it's "polluting ways" from the engine side then. It all comes together.Bob can you explain to me how a bad o2 sensor affects gas mileage? I know that sounds like a noob question but I honestly don't know the answer.
The EPA lab is in ann arbor, and the lab test is a federally regulated standardized test... Actually, it's usually the car companies that run the test using the standardized method... EPA retests only a few of them for accuracy. But it's regulated by law, so if a car manufacturer artificially inflates numbers, they can get fined by the EPA. So it's usually in the manufacturers' best interest to estimate a bit low. Then they can't get flak from the EPA, and customers are happy that they get MPG > estimates.I thought that I read somewhere that the cars are tested in San Diego and somewhere else, like New England...I'll have to look that up and get back to you. I know that they are also tested in the lab, but I thought it was also in 2 differing cities.
I have to second that. I hate crossing over the state line. We try to fill up north of Valdosta before crossing over because we KNOW the gas in FL sucks. About 10% worse economy with that crap y'all have.^Aye.
I just wish I could get rid of this crappy FL gas.
Then, like our "friend", you have been ripped off.Alright everyone, let's act like adults. I just wasted a good 15 minutes cleaning this up and I don't want to have to do it again.
I've filled up the tank to 15.5 gallons on a couple of occasions.
Lately I've been driving speed limit or speed limit+5 because I got a speeding ticket in July and my gas mileage has increased 25-30 miles per tank (so like an extra gallon worth). Good stuff.
Let me explain it to you with an example using numbers, see it that helps...you think you can accurately tell how many gallons you used on a tank of gas. Thats insane.
Perhaps I have been ripped off, though these were on occasions where I was sputtering to make it to the gas station. But what are you going to do? Tell the attendant you want $2.74 back? No, of course you aren't.
How far does the fuel travel before it gets to the tank? I'd be interested to remove a fuel tank and then fill it and the "tube" going into it completely and then see exactly how much it holds. Am I saying Hyundai is incorrect? No. But, you never know how these things are measured and what methods are used.
I also drive until I'm nearly out of gas each tank (unless I know I'm not going to encounter another gas station) add gas beyond the auto-stop. Yeah, I'm a rebel like that...
Just wanted to quote this and re-emphasize the role that air pressure plays in fuel mileage. When you are going slower, there is less air resistance pushing against the car. As you increase speed, it has a similar affect to driving up a hill. Slow and steady is how those hypermilers got 1000 miles out of a tank of gas on the new Sonata.Lately I've been driving speed limit or speed limit+5 because I got a speeding ticket in July and my gas mileage has increased 25-30 miles per tank (so like an extra gallon worth). Good stuff.
I think this is what you meant:does that trip thingy you plug into the data port under the dash read some help here?
My response is to that translation.... No. The under dash scanners merely record what it is you're doin, or if you use the ones with an active display they will show you specific functions going on in the engine. what they might help with is helping you change your driving habits bby showing you how poorly you;re driving.Does that trip thingy you plug in under the dash help you with gas mileage?
