1 - 5 of 5 Posts
Does anyone have any instructions on how to remove the plastic pieces that cover the wiper motor and linkage? Is it clipped in or something? I have a 2001 Elantra GLS. If I start prying it off, is there somewhere I shoudl start and things to watch out for?
Thanks,
Aaron
Discussion Starter #3
I've been searching all over for it. My apologies in advance if its been answered 100 times - I'll try your search criteria, but I had searched/read with quite a few variations. I'll certainly post it if I can find it.
2003 Elantra Owner
Take the seal off first, the seal that keeps the hot engine temperatures from going into your cowl.
There is push pins under that seal. Push in the center, but not too forcefully because if you do the center pin will fall out. Once depressed they will come out. You will have to reset them by pulling the pins out so that you can push them down flush when you reinstall.
1 - 5 of 5 Posts
