I just got these out of the mailbox. Some pics are posted below. The gap in the rings at the bottom is not seen, it has to be cut that way so it can fit the curved surface of the HVAC, the two cuts will be side-by-side when installed. There is one problem. There are 3 indiglo plugs and only 1 plug on the converter :2gunsfiri . Can you splice the 3 plugs into 1? It's AC current, so it should be ok to do that right? The pics are on my spare HVAC, someone else will prob. get these in the car before I do, so they can pick up where I left off.
EDIT
I forgot to mention, it looks like we won't need to cut anything on the HVAC. The 'flat wire' will be able to slip in between the front cover and the assembly, we'll just have to remove the front cover, install and replace. Simple.
EDIT
