1 - 20 of 58 Posts
circuit track whore
Ok everyone, I have been in contact with a US distributor for k-sport coilovers in the U.S.A. for a few months now. I can get as many of these sets as people need with shipping taking no more than 5-7 days (not including holidays) to ship from the warehouse to your door once payment has been received and cleared from the bank. There will be NO minimum to buy to get this pricing. I repeat NO MINIMUM!!!! to buy. I have these coilover systems available for the following vehicles. 1996-2000 Elantra spec coilover system (chy01-kp), 2001-2004 Elantra spec coilover systems (chy07-kp), 1997-2002 Tiburon spec coilovers (chy04-kp), 2003-2005 Tiburon spec coilovers (chy05-kp), 2000-2004 Accent spec coilovers (chy06-kp). These will come with front pillow ball/spherical bearing mounts (which will include fully adjustable camber plates), and the rear will also come with strut mounts (non adjustable mounts). Both the front and rear will also be slotted so there will be no need for additional camber bolts.
below is a description of the K-SPORT KONTROL PRO DAMPENER coilover system.
K-sport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features:
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
Incl. Front Top camber plate Mount, Rear Top Mount.
Spring Rates: Front 7/392, Rear 5/280
pricing is as followed:
for each set, no matter what Hyundai application you need them for, they will be $1035.00. this price INCLUDES SHIPPING!! IN THE CONTINENTAL U.S.A. Shipping to Canada can be arranged for a small nominal fee (usually around 25.00 extra due to customs fees and such). shipping outside U.S.A. and Canada can also be arranged for an extra charge. if you would like shipping insurance as well as tracking numbers, please add $10.00 to cover the cost for both.
here are a few pics of the coilovers as well as the front and rear camber plates.
thanks scott (oiml8/xdgt03) for the pics :D
please post up any questions you have about the coilovers, shipping, or anything in general. I will be happy to answer any and all questions. this sale will be available all the time, no time limits, no minimum to buy.
I will handle everything from ordering to shipping directly to the address of your choice.
turbo envy
Re: k-sport coilovers for all hyundai models available now. low prices,w/no buyer minimum
wow thats not a bad deal!! the only thing different from them and the TEINS are the front spring rate...they are stiffer...and the rear camber plate is fully adjustable...and you can use the EDFC from in the cabin...
they do look sharp! and should work out pretty nicely! good luck with them....let us know what kind of performance you get out of them...i know that oiml has had them for autocrossing and he absolutely loves them!
btw...there is no 2002 tiburon....
With Odin on our side...
Damn good price...with shipping!!!Well.......no bodykit this year. I think I know what my next project will be. Gotta get me a set.....Looks like I'll be doing some OT for the next couple of weeks.....
turbo envy
oh another thing i forgot....these are oil filled not gas charged
circuit track whore
Discussion Starter #5
sorry man, but..
"The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder"
please keep this to the sale and questions of the coilovers. it will turn into one big cluster fvck if we dont
xd tunner
I want a set please! My shipping cost should be a bit more. Which carrier will they use? USPS priority, fedex, ups, dhl, baxglobal, let me know.
circuit track whore
Discussion Starter #7 (Edited)
please pm me your shipping address where you want these sent to. ill phone my distributor on monday and get a shipping quote for you then.
thanks
dave
also, please indicate which model you want (i.e. elantra chy07-kp or tiburon chy05-kp) the prices are the same for all of them, but i will need the model # of the coilover system when i order them for you.
pm sent mayollo072r
Rebuilding the XD
damm I don't have money at the moment but do they having any deals on an EDFC? and this is for sure compatible with the one from TEIN right?
circuit track whore
Discussion Starter #9
the edfc only works on the tein coilovers. i dont think they will work on these. and this is a usa k-sport distributor only, they dont sell the competitors coilovers, sorry. ive seen the edfc's on ebay only once, and that was a while ago. and on other web sites, and if i remember correctly the edfc was around 400.00-500.00 (but i may be wrong).
circuit track whore
Discussion Starter #11
soulless, what i would do is see if anyone could put your payments in an escrow account until you have the total ammount. then make the purchace. these should be available for a long time coming.
xd tunner
thanks
dave
pm sent mayollo072r
PM sent.
circuit track whore
Discussion Starter #14 (Edited)
mayollo072R
pm sent about shipping :D
please clean out your pm box please.
anyway, here is the pm i tried to send you.
i spoke w/the distributor, he says he would rather not ship outside the states..however, he will ship to me, and then I will ship out to you:D i didnt get a quote for shipping, but im sure it will not cost me any more than 30.00 extra to ship to you in PR. so total shipped to you would be 1065.00. let me know if that sounds good to you.
dave
if shipping is less than the extra 30.00 i said above, i will gladly refund the difference back to you.
xd tunner
2loud2k2xd said:
mayollo072R
dave
I cleaned the PM box. Sorry for that one.
That price is just perfect!
So these have a stiffer spring than the Teins? My B&Gs are pretty stiff and I love(d) em, perhaps these are an option.
circuit track whore
Discussion Starter #18
only1db said:
wow thats not a bad deal!! the only thing different from them and the TEINS are the front spring rate...they are stiffer...and the rear camber plate is fully adjustable...and you can use the EDFC from in the cabin.....
slow, here ya go.
Yeah I read that but I wasnt sure if he was talking about the k-sports being stiffer than the Teins. Thanks though!
turbo envy
the TEINS are stiffer but thats because they are made for the gk...these are specifically for the XD...and the xd does not weigh as much...obviously.
1 - 20 of 58 Posts
