1 - 5 of 5 Posts
2003 Elantra Owner
Fuse 25 : Last fuse to the right on the bottom row (3rd) of mini fuses. Interior fuse box, behind the coin tray. Left of the steering wheel.
After replacing, if nothing works, check to see if the fuse blew again.
Discussion Starter · #5 ·
Thanks for your replies.
I switched out fuse 25 like smileymattj mentioned, but the lights still didn't turn on. The car was off when I changed the fuse, but should I have disconnected the battery? Sorry if that's a dumb question: I'm new to this.
Also, I'm not sure if this is relevant, but the key-less entry doesn't work either (I've tested the keychain part, and it works fine, but the locks don't open), and the passenger airbag light is on.
Backstory: I bought the car two days ago, and forgot to check these things :(
Thanks again for the help!
1 - 5 of 5 Posts
