2
Hey folks, my 2003 Elantra XD just hit 164,000 miles and I have a host of problems. I've noticed my rear right break light keeps going out. I usually have to replace it once a month now. The turn signal works along with the running light, but the break light is always going out. I've looked at the socket and it looks burnt up and the worn out bulbs have one connector burnt out when I change them.
Do you guys know the model number for the pigtail connector that goes to the harness? I'm tired of changing these so often, I don't want to get pulled over for a fix it ticket. In my search for answers I looked at my fuse relay box under the hood and I discovered that I'm missing 4 of the fuses that are in the factory diagram:
15A DRL fuse
20A H/LP Washer fuse
15A F/FOG fuse
F/FOG relay
My other question is could these missing parts be causing a short in my system and should I replace these? I didn't know if they came in there stock, I assume so but I don't want to cause more problems.
264.7 KB
192.5 KB
