my transmission swap
65036 Views 101 Replies 31 Participants Last post by  b00nz
its in..
i still have 3 things left to do.
the steering rack needs to get bolted in and to the steering column.
And I bolted up the starter and tried to start the car. sounded horrible. I come to find out the m/t and a/t starters are different? Looks like I'm going to spend 125 dollars of money I don't have to get a m/t one because I never pulled it off the junk car. :( :(
I also have to work out the wiring for the starter circuit. I jumped 2 wires that I thought i needed to jump (power to the line that senses if the car is in P or N) and when the key was in the on position the starter was going. So I need to tap into a "power when crank" wire (somewhere???) in the engine bay and then I'll be good to go with that..
I worked on it for 2 hours last night on my lift, and today I started bright and early at 745, worked straight until a 15 minute lunch brake at 130, and then worked straight until 830pm. I've had a long day and it's not even done yet and will probably end up costing me 125 bucks for a M/T starter :mad: :mad: :mad:
41 - 60 of 102 Posts
cool (Keyan check your PM)
That is really cool.
Congrats. I hope the car works well for the rest of it's life.
More pics please.
congrats dude
i wasnt doubting the validity of this thread, i just wanted to see if the interior was hacked up any from having to swap all that stuff in.
how'd the pedals go in? ok??
what'd you know... keyan can do something right :tongue:
Congrats. So I belive we finally have the first offical Auto to 5-speed swap, WITHOUT BUYING a new car?
haha, deff congrats man!
So what was the final bankroll for this swap? =P ...considering labor was on you.
he got the orginal donor car for pretty cheap so it wasn't that much at all.
I had to drill through 2 layers of sheet metal of the firewall for the pedals. I did it months ago. That was definately the worst part of the entire swap.
Donor 2001 Elantra = $140 bought, $135 to tow it
New Transmission because donor's got f'ed up (read: destroyed in donor car's accident) = $450
New Throw out bearing = $42
Resurface flywheel = $30
Manual Trans Fluid = Don't remember
I'm sure there is a bunch of other things I don't remember.
I still have to buy a gauge cluster, a manual transmission ECU, and interior shifter boot and m/t center console trim.
are those Tiburon Seats?
yes, but I have an aig bag light because the 05 aig bag wiring system is completely different :( My next project is to solder in the old connectors and resistors to make the system happy again ;)
uhh....thanks?
I have an 03 GT cluster and the manual ECU. Let me know.
I can't use the cluster because it's an 03, but is the manual ecu from a cvvt 03 or non-cvvt?
what is different about he ecu?? i though they just added the tranny ecu as an extension?
good job!!
good job!!
the TCU and ECU are in the same computer
But they are seperate.
like 2 people living in one house.
Nice:abovelol: :abovelol: :abovelol: Good way to put it! Looks good man, I can't wait till it's all together with the ECU, cluster, and all the trim and stuff.
seems liek someone else posted a while back that he did an auto-->manual swap....IIRC, he was having some wiring issues or something
Sorry, didn't realise you need an XD2 ecu. It's 03 non-cvvt ecu.
:abovelol: gotcha...that is a good way to put it
