1 - 8 of 8 Posts
Had A/C just the other day and now nothing.
2004 Elantra GT
Green light on dash working - don't feel the drag on the engine or hear any clicks, and no cold air. I checked the obvious fuses and all were ok. I suspect either a relay or there is not enough "freon" in the system. Your thougths?
2.Slow
jesse had an issue with his ac not working. he hot wired the power to the AC directly to the battery. then it worked. but then again... hes the genius that drilled into his ecu harness or something... i doubt ud do that.
Super Moderator
I'm not too well versed in a/c systems (an area I never really got into) but won't it fail to turn on the compressor if its low/out of freon?
Low PSI safety switch. If there is not enough R1344/freon, the A/C compressor will not turn on. It is to save the compressor so you do not burn it up form lack of oil/freon. You will have to have your A/C system recharged. There could be a leak, so maybe go for a leak detection test first.
Super Moderator
^Thank you, I thought so but wasn't sure.
1 - 8 of 8 Posts
