1. Evo Fusion CAI
2. ARK Catback exhaust w, custom 2.5 inch flex delete and magnaflow hi flow cat. (turbo ready)
3. Magnecor wires
4. NGK v-power plugs
5. Mobil One full synthetic
Transmission
1. 06 transmission with triple cone syncros
2. Slave cylinder modification (spring removed)
3.Redline MT-90 tranny oil
Brakes
1. Magnum drilled GK rotors front/rear
2. Magnum Ceramic GK SE pads
3. GoodRidge Stainless Steel Brake lines
4. SE calipers (Aluminum) Front
Suspension
1. H&R Springs with Tib KYB GR-2 struts...coils are gone!
2. Whiteline Adjustable sway bar. (18-22mm) currently on 22mm w/ poly bushings)
3. Ingalls Engineering adjustable rear trailing arms
4. Performance Alignment (front camber -2.0, toe 0.00) (rear camber -1.5, toe 0.00)
5. 17" split spoke GK wheels
6. OEM 215/45 r 17 michis...soon to be 215/40 r 17 (or possibly 225/40's)
7. Full 5 lug swap
8. 15mm bolt-on hubcentric spacers
9. Mussa front strut bar
10. Midbody brace (maker unknown)
1. Eclipse 8051
2. Eclipse DSP 2103
3. Eclipse PA 4212
4. Eclipse 32440
5. Diamond Audio 6.5 hex components
6. Diamond Audio 6.5 coaxial
7. Diamond Audio 12" Dual 2 ohm coil....in custom trunk enclosure
8. 1 Farad Lightning audio capaciters x 2
9. Sound deadening by Casade Audio
10. MOMO alum shifknob
11. 04 Tiburon driver seat (cloth) (wife doesnt like the feel so there is only one of them)
12. Dash painted Flat black (OEMish but different)
1. Touring Cup front spoiler
2. 04+ tail lights (reded out turn signals)
3. custom painted front grill (flat black and that the way its staying!)
4. wingless hatch
5. PIAA Plasma Ion Yellow H3 foglights
6. S2000 oem Antenna
QUESTIONS:
CAN YOU TELL ME FROM WHAT VEHICLES ARE ALL THIS MODS? I MEAN, HOW I KNOW WHAT TO BUY? I HAVE A 2003 HYUNDAI ELANTRA GT HATCHBACK 2.0 MANUAL TRANSMISSION AND I WANT TO MAKE IT RUN FASTER AND BETTER.
ALSO:
DO YOU GUYS KNOW WHAT YEAR TIBURON V6 ENGINE, TRANS AND ECU FITS ON MY CAR?
