1 - 8 of 8 Posts
2006 elantra gls, 52k miles, MIL came on 3 days ago, 'kicks' when shifting to reverse, on drive uses only 3rd gear...
scanner showed P0885, according to http://actron.com/code_lookup.php it is "Transmission Control Module Power Relay Control Circuit/Open"
i already spent few hours trying to google it - no results, and spent some time on www.hmaservice.com, also without much progress - found schematics for fuse/relay boxes but there was nothing about TCM... should i remove every relay and fuse and check it? is it possible that TCM relay is on or near TCM? where is TCM located then?
will appreciate any help... :)
ps. if someone have problem with P0711 or P2096 on 2005 hyundai accent i may have some tips
Discussion Starter · #4 ·
yep, just the relay, do you have the same problem? p0885 can be from {relay, broken cable, bad harness connector, broken tcm/pcm, or blown fuse} but it takes less than 5 minutes to check if it is relay, it is too late tonight but tomorrow (if i dont forget) i will post photo/ video with location
Discussion Starter · #5 ·
if you want to check it in hmaservice.com look for P1723
Motor vehicle Automotive exterior Automotive design Auto part Vehicle
Electrical wiring Gas Circuit component Electrical supply Cable
Finger Electrical wiring Audio equipment Gas Electronic engineering
when you remove the relay, just connect upper right and lower right connector with some wire, then start the car, if it drives normaly just go to dealer and buy a new relay
Hi Mazzich,
I just wanted to thank you so much for your post. I've scoured the internet on this and couldn't find anything. I also have a 2006 Hyundai Elantra GLS with only 25,000 miles on it that kicks when it's shifted into reverse and it has the check engine light on. I don't know about it being stuck in 3rd gear, but it does take a long time to accelerate. Once it's up to speed, it drives normally.
Unfortunately, I have a few error codes: P0700, P0885, and P0038. I've looked up the meaning for each and only P0700 and P0885 have to do with the transmission (P0038 is for the oxygen sensor and only used for emissions regulations).
When you removed the power relay cable and connected the upper and lower right connector with wire, did that turn off the engine light and stop the car from kicking when shifted into reverse?
Thank you so much for your help. I really appreciate it!
-Derek
1 - 8 of 8 Posts
