1 - 4 of 4 Posts
I found some pinhole leaks in my radiator at the top, I've attached a pic not the best quality but you'll have an idea of location. Is there anything recommended to use to repair. I don't have the money to replace it at this point as I also need to replace the rear calipers and pads. Plus the leak is small and slow so I know I can watch it and top up when needed.
2003 Elantra Owner
Can't tell from the pictures, but you can see the hole right?
Use a two part epoxy glue like JB Weld, it should be able to seal it.
Discussion Starter · #4 ·
I cleaned it up and fixed it today, it turned out to be cracked along the top plastic part. Hopefully the fix holds until the cash flow is in better shape so i can replace the radiator. Thanks for the advice
1 - 4 of 4 Posts
