Hello, I had a question about blow off valves and forge diverter/dump valves... Ok, so, I understand that streight from the intercooler or turbocharger a tube will lead into the throttle body, and on this tube is where the blow off valve would be located, and from the vacume line comming off the intake manifold would connect streight to the blow off valve, so when the butterfly valve closes, there will now be a vacume inside the intake manifold, which will then trigger the blow off valve to open letting all of the pressurized air escape so your turbocharger doesn't sieze etc., but my question is this... the MAF sensor reads the air that is passing through, so it expects that the engine is going to burn it, so the computer is going to mix in the correct amount of fuel, but the problem is that when the blow off valve lets all of the air escape, the computer thinks that all the air is going to get burned, but instead the air isn't there so its going to be super rich. So, is this a problem? And also I heard that a Forge Diverter/Dump Valve is a mechanism that will solve this problem, but I don't understand how one of these devices work so just curious if someone could explain this to me, thanks! Any help is appreatiated
