1 - 5 of 5 Posts
I am in the process of replacing my radiator, as i got into a little accident, yada yada. I had take the top radiator support off, that also has the horns mounted on it that looks like a T basically, to bend it back into shape. I seem to have misplace the 6 top bolts, 3 on each side, that hold it down, and i need to go buy new ones if I cant remember where I put them.. and the one that connects it at the bottom of the T. Could anyone tell me the size or type of bolt to get at a store like true value?! like threads, legnth or anything just so i can bolt the piece in there. lol i couldnt find any information on what bolts they are online..Much appreciated!
2003 Elantra Owner
Top 6 are 10mm Hex Heads. Not sure the thread size. All metric. Bottom bolt on the T is larger, can't remember. 10mm is used highly through out the car. You can take one out and take it to the hardware store. Bolts that hold the fenders on on the side of the engine bay are identical just a different color.
Try to get something that won't rust.
1 - 5 of 5 Posts
