Alright, as the topic says, went to replace the fuel filter on my Elantra. Not a simple job, but I did exactly as the Elantra Shop Manual stated. Here are the steps:
Remove rear seat cushion
Open access cover to Fuel tank
Disconnect Negative from Battery
Disconnect wiring harness from Fuel Pump assembly
Reconnect Negative to Battery
Start the engine and allow it to die on its own. *This removes fuel line pressure*
Remove screws holding Fuel pump assembly in tank
Remove hoses connected to fuel pump assembly *watch for spilled fuel*
Remove fuel pump assembly from tank *Use a towel to avoid spilled fuel*
Remove clips holding fuel filter into fuel pump assembly
Replace fuel filter and reassemble fuel pump
Check for fuel leaks
Thats it. LOL sounds simple, it was until I got to pulling the fuel pump assembly out. The Shop manual, its whole 480 pages of fuel system, only has 5 pages related to the actual fuel system and 475 pages of electronics diagnostics for the Fuel injectors. What a waste. There were no pictures to help with this replacement in the filter replacement section. And the picture of the fuel tank blow up only show the fuel pump assembly but doesn't break it up. So its worthless when trying to pull the dang thing apart.
Ok So I replace the filter, reassemble everything in the order I took it apart. reconnect the battery. Get in the car, turn the key, and it just cranks. So I turn the key to ignition on, but not to start to hear for the fuel pump activating. Sure enough I hear it come on, so I turn the starter. Still nothing, just cranking. Try that 10 times... Still nothing. So I call the dealer just to see if a tech can help me out. He said try it 5 more times, if nothing, then pull the fuel line just before the fuel rail, then crank it and see if fuel comes out. So I try, this, and yes, fuel comes out. Meaning there is pressure coming from the fuel pump.
So here I am, stuck. I pulled the fuel rail and injectors loose to see if any fuel is being released by the injector. Crank it, nothing comes out. I pull the spark plug on the #4 cylinder to check if its flooded. Nope dry as dry can be. No odd coloring. So I spray some carbrator fluid in all four cylinders, just to see if I have ignition. LOL And to also see if combustion can make some vacuum to start the injectors. Engine cranks, starts for 5 bangs, then stops. So I got spark, but not fuel from the injectors. Next I'll try some starter fluid see if that works. Anyone have any suggestions why I'm not having any luck?!?!
