ok people,
for the last time. Lowering your car WILL NOT make you have a transmission leak. It simply WILL NOT. You are not altering the angle of any suspension parts. You are not change caster camber unless you put big ass hondarific wheels that don't fit into the wheel well when you lower it. The angle of your axles, tierods, control arms, bushings, sway bar, sway bar links everything will be exactly the same as long as there is a uniform drop in the springs.
For argument sake, think about that reason:
Your axle changed angles.
How is this possible? Does your engine and transmission stay at stock height and everything else drops? This is PHYSICALLY IMPOSSIBLE!
Stop beliving everything your dealer tells you. Believe me we changed out at least 3 automatic transmissions EVERY GOD DAMN week at Key Hyundai in Milford, CT. You can call there and ask for Paul he is the head mechanic and tranny guy. Ask him how the betaII auto trannies are...
sometimes i just don't know...
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
shawn
