1 - 16 of 16 Posts
Ninja Super Mod
Here's the diagram I promised you guys, drawn by the man Denis himself! :bowdown:
1st diagram is for the turbo box only
2nd one is for the beta2 MAP based,MAF based use the exact same pin out but the setting for the smt-6 switch function will be different
computer pins are in order fropm left to right
45 32 29 60 1 3
smt-6 settings are 4 cylinders
60 teeth per turn
30 teeth per firing
mode 1 (missing tooth)
pos input pol ON
pos output pol ON
low level ON
AMP (map sensor) in the dos box calibration for the Gm 3 bar are
AL 2 0 95
AH 15 15 183
(those might vary a bit depending on altitude and local atmospheric pressure)
smt-6 switch setting (to activate turbo box) 2.5 psi
[/QUOTE]
Bigger:
CLICK HERE (auto resize crops it too much so I had to link it)
This is how to wire the SMT-6, with the turbo box, and dual fuel rail kit, for a MAP-based Beta2.
I wrote optional for the fuel map switch, because, well, you need to program the second map for that, and not many people do this.
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
Super Moderator
Re: SMT-6 Wiring Diargram For Beta2 MAP
interesting, i'm sure this'll help alot of people.
Eldiablo owner
nah still low tech ;-)
i'll make a diagram on the computer using one of or "blank" diagram sheet
should come up a bit clearer
Final Fantasy 7=Teh Sex
i had to use this to wire up Ishmael's car, boy was it hard to read.
I am having trouble wireing up the Crank sensor once we splice in it wont turn over
Can whoever knows about wiring this up please call me
631-926-7470
i need to figure out this crank sensor issue. everytime we splice into it, it doesnt turn over
Eldiablo owner
those might help, i'm not sure how clear they will show on your screens...
computer pins are in order from left to right
45 32 29 60 1 3
60 teeth per turn
30 teeth per firing
pos input pol ON
pos output pol ON
low level ON
AL 2 0 95
AH 15 15 183
Beta Accent
If you guys dont mind, I have a few questions about the turbo box.
1)Is its purpose to put the car into open loop?
2)How does this benifit me?, Does the ecm not care about rich fuel trims in open loop?
3) Can I activate it without the smt6? Like with a hobs switch instead?
4) Am I in open loop at WOT?
Thanks
1 - 16 of 16 Posts
