scarfache said:Does anyone know how to let the xd reach its full potential? There is a speed limiter at 113 mph and I would like to go a little faster than that. Any help with that would be great. Thanks
Rich
Here's the whole thread if you want to read any of the following comments http://www.elantraxd.com/yabbse/ind...splay;threadid=9058;start=msg103688#msg103688guys, to disable the limiter simply disconnect the wheel speed sensor harness.
just unplug it and tape it to the side for the ride..
go on the highway and test it out..
remmeber, the speedo WILL continue to work because the speedo runs off the transmission..
the ecu will trigger a CEL because it will not see the sensor..
then try out the top speed and try to break the 120 mph limit... then take a pic of the results and post it on here !!!!!!!!!!!
it either works or it doesnt ... simple as that.
