Hey guys i will really appreciate your help on this one.
I have a 1999 mitsubishi lancer GL - the dash board has no RPM and the teperature gauge is a big one.
Today i have replace the dash board with another mitsubishi dash board that has RPM and the temperature gauge is small
now the reading in the new dashboard is high!!! you may consider the zero point in the middle, however when you turn off the engine the needle goes all the way down.
when putting back the old dashboard the reading correct.
is there a way to calibrate the needle or do something to fix this issue.
Thanks!!
Thanks!!
