Just FYI for you guys with '04's... If you decide to get the tib pedals for your ride, you will need to go to your local dealership and order a gas pedal assembly for an '01-03. The gas pedal in the 04 is totally rectangle and very thick. The tib pedal is sort of diamond shaped and very thin. Also, the 03 pedal does not swivel like the 04. So, in short, spend an extra 20 bucks so your metal gas pedal will fit properly. The brake and clutch will work just fine with no mods. There are so many things that are the same on the 04's, but there are just as any things that are different. For those of you that want the gas pedal to fit your 04, order this part number from your local dealer.
32700-2D000. That will solve all of your problems
