Hello XD owners,
I installed the tiburon swaybar upgrade today with poly bushings and moog metal endlinks. When installing the bar is hitting the frame and rubbing against the gas filler tube. I just went ahead and installed it anyway hoping it would clear once the car is on the ground. When I drive it it clunks over bumps. Does it take time to self clearance or did I install it wrong. I matched the bends to the stock swaybar and pretty sure its on the correct way. Not sure if anyone else has encountered this issue.
EDIT: Installed swaybar the wrong way, see the video I made to avoid this issue and install it correctly!
