So yesterday I replaced the timing belt on our 2005 elantra 2.0 and now the car wont start. I have done timing belts before but this one was weird
Everything came apart and went together fine the problem i had was timing the car...
I lined up the crank sprocket with red mark-that went fine
Then i lined up the crank sprocket with the "timing mark" on the block but this was the problem i believe! what is the mark!? I used the "line" that was to the left of an indentation. Was I supposed to use the indentation? The indentation seemed to wide to go by so i used the line.
Also even if I was off a tooth wtf wouldnt the car at least start? Car has spark and fuel so it must be a timing issue.
Any help would be great, if anyone is feeling generous and wants to help me over the phone it would be greatly appreciated.
