Vote for COTD - 2011 edition
  • bdiggy
    Votes: 2 4.8%
  • evilcalvin
    Votes: 1 2.4%
  • only1db
    Votes: 9 21.4%
  • ilanpro
    Votes: 9 21.4%
  • SilverElantra
    Votes: 3 7.1%
  • songee623
    Votes: 3 7.1%
  • XTRAWLD
    Votes: 2 4.8%
  • mayollo072R
    Votes: 13 31.0%
Status
Not open for further replies.
1 - 3 of 3 Posts
bdiggy
Started with the old rims and graphics pics, then on to present status.
Modifications
Road Runs grill
Clear signal head lamps
Smoked marker lights
35% tints
13" euro antenna
Smoked tail lights
Silver painted brake calipers
4500k HID los
3k HID fogs
Door chime delete
TWM short shifter
Painted switch plates & HVAC
TWM weighted shift knob
Redline custom leather shift boot
Blue neon door lights
Blue neon trunk light
Fully Dynamatted trunk
Smoked dome & map light's
Custom 2-toned rear speaker grill's and 3rd brake housing
Audio/Video:
JVC HD CD head unit
JVC Ipod interface
80G Ipod classic
XM tuner
Memphis 1000w PRD mono
12" Type R Alpine sub
Custom Evilcalvin sub box
Suspension/Brakes:
H&R Sport springs
KYB GR2 Elantra struts
Drilled/slotted rotors
17x7 ADR Venemous 42mm offset
215/45/17 Lexani N3000 tires
ARK front strut bar
19mm Tib sway bar
Energy Suspension greasable poly bushings
Engine/Exhaust:
Custom 8ga blue ground wires
Ebay 3" SRI
AEM Dry Flow filter
Hood spacer's
EF catback
evilcalvin
This is the 2002 Hyundai Elantra GLS "Evil Edition"
Custom made Mods:
Custom made pilars for mids and tweets
Custom made 12 volt display in clock location
Custom made door panels for midbass
Custom made storage compartment for second battery, safety accessories
Custom made amp rack for amps, amp cooling, power inverter and voltage display
Custom made subwoofer enclosure
Custom made grille for front of car
List of electronics:
1 Autopage C3-RS730 2 way remote start alarm
1 Pioneer AVH-P3200BT for radio and bluetooth
1 Boston Acoustics GT-2300 1 channel by 1500 watts sub amplifier
1 A/D/S PH15 6 x 55 watts channel amp fronts
1 1 Audiocontrol 6XS Processor amp line driver
2 Kicker Comp VR 8" midbass drivers
1 Kicker L7 Solo-baric 12" DVC subwoofer
2 CDT TW-25s silk dome tweeters
2 Aurasound ND Whisper titanium 2" mids
2 Street Glow red led clusters under dash
3 red leds added to center console and cup holders
2 Radisys Systems 3.5 volt high grade blue leds in trunk
2 Street Glow white led strips around headlights
1 Stinger 160 amp circuit breaker
1 Stinger 160 amp digital circuit breaker
1 Shuriken 950 cca car audio battery
1 Monster 1 farad cap
1 Coleman 800 watt power inverter
Sound Deadening:
150 sqft. Raamat BXTII deadening material
8 sq. yards of Raamat Ensolite applied everywhere including roof
fiberglass and resin applied to trunk cavity for noise suppression
6 cans Great Stuff triple expanding foam applied to all pilars and trunk
Engine, Suspension, Etc. Mods:
Cold Air Intake with Short filter
The big 3 wire upgrade to 4 gauge on alternator, engine and battery
Shark Racing Strut tower bar
Hyundai Tiburon 21mm rear sway bar
Bosche Spark plug cables
Bosche Platinum spark plugs
Sumitomo 205/15/60 directional tires H rated
MB Wheels 15" all lugs are locks
Painter calipers and drums
LLumar window tint 30% on fronts 5% on all others
3 novel washers
Here are the pix:
only1db
1. Evo Fusion CAI
2. ARK Catback exhaust w, custom 2.5 inch flex delete and magnaflow hi flow cat. (turbo ready)
3. Magnecor wires
4. NGK v-power plugs
5. Mobil One full synthetic
Transmission
1. 06 transmission with triple cone syncros
2. Slave cylinder modification (spring removed)
3.Redline MT-90 tranny oil
Brakes
1. Magnum drilled GK rotors front/rear
2. Magnum Ceramic GK SE pads
3. GoodRidge Stainless Steel Brake lines
4. SE calipers (Aluminum) Front
Suspension
1. 03 Tiburon Tein Super street coilovers
2. Whiteline Adjustable sway bar. (18-22mm) currently on 22mm w/ poly bushings)
3. Ingalls Engineering adjustable rear trailing arms
4. Performance Alignment (front camber -2.0, toe 0.00) (rear camber -1.5, toe 0.00)
5. 17" split spoke GK wheels
6. 215/40 R 17 Nitto Neo Gens
7. Full 5 lug swap
8. 15mm bolt-on hubcentric spacers
9. Mussa front strut bar
10. Midbody brace (maker unknown)
1. Eclipse 8051
2. Eclipse DSP 2103
3. Eclipse PA 4212
4. Eclipse 32440
5. Diamond Audio 6.5 hex components
6. Diamond Audio 6.5 coaxial
7. Diamond Audio 12" Dual 2 ohm coil....in custom trunk enclosure
8. 1 Farad Lightning audio capaciters x 2
9. Sound deadening by Casade Audio
10. MOMO alum shifknob
11. 04 Tiburon driver seat (cloth) (wife doesnt like the feel so there is only one of them)
12. Dash painted Flat black (OEMish but different)
1. Touring Cup front spoiler
2. 04+ tail lights (reded out turn signals)
3. custom painted front grill (flat black and that the way its staying!)
4. wingless hatch
5. PIAA Plasma Ion Yellow H3 foglights
6. S2000 oem Antenna
and this is as the car sits right now...literally! haha
ilanpro
Ilanpro 2004 Elantra GT turbo
Modifications
95% of all work was done by myself
Custom Blue Daytona Pearl
Custom Fitted 01-03 Concepto Body Kit
Custom Fitted Protege Mazdaspeed rear Spoiler
LIMITED Front Grille
Shaved antenna
KDM Clear corners Headlights
8K HID low beams and Fog lights
CCFL ANGEL EYES
Custom Painted To match the outside
Cobra Replica Misano Black and Blue Seats with Matching rear seats
Isotta Steering Wheel
Isotta e-brake and Boot
Issota Gear Shift
KDM Tiburon pedals
Ebay Short Shifter adjusted for shorter throw
Clarion VZ409 DVD Flip out
Chrome Door Handles
All green lights turned to blue by me
Sirius Radio
Stock internals To be replaced some day
Jattus stageII turbo kit
2.5" straight exhaust
Suspension/Brakes:
H&R Springs Gabriel struts
Giovanna 17" Wheels with 205/40-17 NEXEEN Tires
19mm Swaybar
Moog endliks
XG Dual Piston Calipers with sonata Slotted rotors
DO NOT POST IN THIS THREAD!!!!!!
Discussion Starter #2
SilverElantra
KDM Side Skirts
KDM Clear Side Markers
Hyundai OEM Trunk Lip Spoiler
Road Runs Grill
Paint Matched Chrome Hood Piece
Tomato Eyelines
Custom Cleared/Smoked Tail Lights
AntennaX 13" Euro Antenna
Compact Divisions Silver Fiber Mirror Covers
17X7 Reaction Mesh Wheels W/Nitto NeoGen 205/40ZR-17 Tires
ElantraHD Badging/SeoulfulRacing Sticker/Mussa Emblem
Tinted Windows 5% Rear & 50% In Front
Custom Headlight Clear Corners
R-Racing Motorsports Super White Bulbs
4" Muffler
System Titanium Oil Cap
Compact Divisions Carbon Fiber Fuse Box Cover
PilotMotorsports Black Leather/Chrome Automatic Shift Knob
M3 Black Leather Shift Boot
Blue Guage Lights
SharkRacing Aluminum Racing Pedals
OEM Metal Footrest Pedal
Dreamka4U OEM/KDM Ticket Holder
Audio/Video:
Pioneer P3000MP Head Unit
Two 12" Phoenix Gold Subs
Ported Box
Boss 1200W Amp
XScorpion 3 Farad Capacitor
Competition 4 Guage Wiring
Suspension/Brakes:
Rotorworks Drilled/Slotted Rotors
Posi Quiet Ceramic Pads
SpringTech Lowering Springs
Ingalls Camber Kit Front/Rear
SharkRacing Rear Strut Bar
EZACCESSORY 5MM Wheel Spacers (Front)
KAutoAnything Carbon Fiber Front Strut Bar
AEM Polished V6 Tiburon Cold Air Intake
Custom 2.25" Catback
10.2mm Blue Spark Plug Wires
MagnaFlow High Flow Cat
Maintec GT Header
This is my updated mod list.
EXTERIOR:
Garage Door Front Lip
KDM Side Skirts (Currently off the car)
Tomato Eyelines
Diode Dynamics 4" Antenna
17X7 TenzoR Type-M Wheels W/ General Exclaim 205/40-17 Tires
ENGINE BAY DRESS-UP/PERFORMANCE:
NGK Iridium Plugs
EvoFusion Catback Exhaust
INTERIOR:
OEM Front Leather Seat Skins
OEM Leather Arm Rest
Blue Guage Lights
Dreamka4U OEM KDM Ticket Holder
STEREO:
Ported Box
Boss 1200W Amp
SUSPENSION/BRAKES:
Energy Suspension Bushings
Tiburon 19mm Sway Bar
Springtech Springs
Ingalls Rear Control Arms
songee623
Performance
aem bypass
bored out stock trottle body 63mm
acceleration pully
accord cold air/ short air intake 3inch
engine torque damper kit (blue)
catch can mod
voltage stablizer
engine ground wire kit home made (black)
evofusion (gen 1) catback exhaust with silencer
ngk plug wire's (blue)
oil temp gauge ( 7 color tinted )
oil pressure gauge ( 7 color tinted )
vacuum gauge ( 7 color tinted )
custom digital volt gauge ( switch blank used )
tsunami -negative battery terminal (Satin Nickel Finish )2 =0/4g 2=8g
optima red top battery
Engine Bay Dress Up
black silicone hose for catch can
blue silicone hose for radiator over flow tank
blue silicone hose for window washer
black silicone coupler's on intake
window washer hose tucked into hood
custom maf cover with avante xd in chrome
chrome oil cap cover
chrome radiator cap cover
window washer cap, power steering cap, brake resovior cap all painted blue
fuse box custom blue paint job with skull
radiator support's painted body color
battery hold down painted body color
Body Mod's & Lighting
Evofusion 4 part lipkit
DDM 4,500 hid kit with wiring harness for stock fog light's
DDM 4,500 hid kit with wiring harness and glare sheild's (tricked)
kdm headlight's with clear turn signal's
after market mesh grill
lower bumper meshed to match top grill
tinted window's 30% all window's
avs window guard's
custom gt badge in place of H on trunk
shaved emblem's on trunk
white after market fog/running light's
kspec carbonfiber badge
euro short antenna
kdm chrome door striker's all 4 doors
fiamm high & low horn's
headlight eyeline's
kdm blue mirror's
kdm led turn siginal mirror cover's
m3 lip on back window
kdm molding's with out amber light's
turn singal's changed to xd with running lite and turn singal up front
5 smt city light's
red natural glass third brake light
chrome/amber turn signal's rear
red natural glass brake light's
red natural glass 194 running light's
9 smt led back up light's
(summer tail lights)
tinted tail light cover's
Wheel's & Suspension
19.2mm tiburon sway bar/energy suspension bushing's (red)
falken tire's ziex ze 512 215/145zr17
falken rim's torque 5 glossblack w /polished lip 17x7 23lbs
stock gt rim's winter wheel's
road race motorsports front strut bar
shark racing rear strut bar
Interior & Lighting
issotta leather shifter boot
isotta e-brake handle & leather boot
tiburon pedal's & dead pedal
kdm chrome tweeter ring's
elantra chrome door sill's
sparco seatbelt pad's
3 x led light's in center vent's
2 x led light's in left and right side vent's
custom frosted and back lit gt badge in passenger side dash pocket
strobe light's and custom clear door marker light's
6 inch blue neon's in front door pocket's
led light's in all 4 door handle pod's
matte body color door handle pod's
switch plate's matte body color
kdm chrome door handle's
dome light matte black
dome light blue 18 led's
door chime dissconnected
12 micro led light's in front speaker grill's
kdm xd2 ticket holder
custom mission plate with skull
hvac & clock swap (blue color)
kdm hvac knob's
hvac face painted body color
1 led blue in ash tray
1 smt led blue lighter
1 smt led blue ignition ring
triple gauge pod
6 x 9 inch neon tube's
2 x 6 inch neon tube's
6 x strobe light's
3 adjustable led's in large part of arm rest bottom part
5 smt led map light's
3 micro led's in change bin
3 micro led's in top part of arm rest
6 micro led's in sunglass holder
15 micro led strip on bottom of door panel (wired to clear door light)
5 micro led's under back seat cup holder
2 x 6 micro led's in front cup holder's
small ac vent's on dash by A piller body color
cap's for roof handle's painted matte black
back deck speaker cover's 2 color body color and matte black
3rd brake light housing 2 color body color & matte black
sunglass holder matte black and gray
In Trunk & On Amp Board
10 strobe light's in trunk
10 inch purple neon tube
3 x 10 inch blue neon tube's
15 inch blue neon tube
12 blue micro led light's in tiburon sub shell
4 strobe light's on amp board
8 x 6 inch purple neon light's
3 micro led's in fuse block
15 purple micro led light's in 6 1/2 speaker grill's
3 fighter style switch's for strobe's, blue neon's, purple neon's
trunk floor redone with carpet to match amp board
black chrome fire extinguisher
Audio & Video
back up camera
7 inch flip jensen with ipod hook up
tiburon inifinity sub shell with polyfill
4 way audio guage temp, vu left, vu right, volt
aura bass shaker's
soundstorm F2.200 amp
infinity reference 5350a amp with sub remote control
infinity reference 850w subwoofer
infinity reference 9613i 6x9 3 way
infinity reference 6012i 6 1/2 2way
infinity reference 6020cs 6 1/2 component's
boom matt speaker baffles 6 1/2
9 inch monitor on trunk lid
6 inch monitor on amp board
boss bvam5 video singal amplifer
all power / ground wire's and block's tsunami
4 gauge power wire and ground
8 gauge power wire and ground
4 gauge in two 8 gauge out fuse block
4 gauge in five 8 gauge out of ground block
1.5 frad digital power cap
4 way rca's front/rear and 2 way rca's sub
36sq feet of dynamat
36sq feet of 1/8 Dynamat dynaLiner
60sq feet of Edead 45
trunk floor redone in black carpet
XTRAWLD
XTRAWLD'S 2002 HYUNDAI ELANTRA GT1
I'm posting my September 2004 Car of the Month winning car as it was the day it won. I still own it, but the pics are from her glory days.
AEM 2.5 inch Cold Air Intake with K&N Filter
Redline Synthetic Transmission Fluid
Royal Purple Synthetic Engine Oil with Fumoto Valve
Remus Catback Exhaust
Suspension and Wheels
Quest HR Series Coilovers with Pillow Mounts
AOS Front Strut Bar
Katana C10 Hyper Black Rims
Falken Ziex ZE512
McGard Tuner Lugs
Custom Painted Interior
Blue Neon Lighting
‘03 Tiburon Pedal Set
KDM Chrome Door Handles
TWM Titanium Short Shifter
Momo “Sphere” Chrome Shift Knob
Custom Stainless Steel Elantra GT Door Sills (Front and Rear) - c/o Playboyz28
Ixion Body Kit, Molded Side Skirts and Grille
JSP Carbon Fiber Wing
Extreme Dimensions Carbon Fiber Hood
Compact Divisions Carbon Fiber Side Mirror Covers
Ixion and KDM Emblems
‘01 Tiburon Antenna, Fog Lights
I.C.E.
Pioneer DEHP-740MP
Kaption 5.5” Coax Speakers
Kaption 5.25” Component Set Speakers
2 12”Rockford Fosgate Sub Woofers HE2 With Custom Enclosure
Rockford Fosgate Amplifiers, 1000 and 600 Watt
Rockford Fosgate Digital Battery Capacitor
mayollo072R
This is the list of Mods to date
Suspension
1. 18" 5Zigen inperio graphite wheels
2. Progress 23mm rear anti-sway bar
3. Mussa rear strut tower bar
4. ARK front strut tower bar
5. Toyo Proxess 215/35/zr-18
6. 12" Big Brake kit
7. Ksport coilovers chy07-kp
8. Stoptech rear disks and brake lines.
9. Skunk light weight Lug Nuts.
10. ARP Extended lugs
11. Progress 22mm rear anti-sway bar
Engine and tranny
1. Kspec Airram powder coated.
2. OBX Adj. Cam gear
3. Shark Racing underdrive pulley
4. JS Speed pulleys
5. System Upgrade 63mm BBTB
6. 850cc injectors
7. OBX ceramic coated turbo manifold
8. Turbonetics 38mm wastegate with 14.7 spring
9. 3 inch custom downpipe.
10.Turbonetics 60-1 T3/T4 turbo
11.Turbonetics Raptor BOV
12.28x11x2.5 Sparco FMIC
13.F1 Light weight flywheel
14.OBX oil catch tank
15.OBX and turbonetics and hoses clamps
16.Walbro 255 gph fuel pump
17.ARK 25 catback
18.Nology hotwires
19.Racing NGK grade 9 spark plugs
20.Koyo racing radiator
21.Stage IV, 5 puck clutch
22.Redline MT90 gear oil
23.Oil cooler
24.APE shifter bushings
25.KFX Solid motor mounts
26. Balanced engine
27. Pauter beams
28. Cp 82.5 pistons
29. Return fuel line set-up with aeromotive A1000
30. Microtech LT10s standalone with X4
31. 3" QTP electronic Cutout
32. Many ARP 12 point sSS bolts and nuts and many polished stainless steel bolts
33. Jattus engine damper (awesome part)
34. Many AN fittings and braided hoses
1. Fiberimages CF vented hood
2. KDM Jenis front bumper and grill for GT
3. KDM M&S sideskirts and rear bumper for XD2 modified
4. Custom color
5. KDM headlights
6. Fiberglass custom eyelids made by Compact Divisions.com
7. Compact Divisions CF mirror covers
8. Compact Divisions CF window trims
9. M&S emblems
10.KDM trunk garnish
11.Avante xd emblem
12.XD2 projectors foglights
13.Shark attack II antenna base with VMS CF antenna mast
14.Custom R34 rear spoiler (removed for flat black combo paint)
16. KDM DOHC badge
1. EL gauge cluster
2. C2 gauges (EGT, OIL press, OIL temp, Boost, Volts,AF, RPM, Shift Light)
3. Compact Divisions CF double Gauge pod pillar A
4. Compact Divisions CF HVAC trim and ABC pilars
5. KDM Chrome instruments rings
6. KDM OEM Metal pedals
7. KDM Avante XD door sills
8. KDM Chrome pull cup
9. Custom trim paint
10.KDM Ash tray and coin pocket
11.MOMO Millenium EVO steering wheel and adapter
12.MOMO COBRA shift knob and MOMO leather carbon shift boot
13.MOMO Street racer GT seats
14.MOMO Floor mats
15.MOMO seat bealts
16.MOMO Seat sliders
17.MOMO e-barke handle
18.MOMO e-barke boot
20.Sparco tabbed seat brakets
21.Compact Divisions.com CF door panels
22.Compact Divisions.com CF console lid
23. KDM interior chrome door handles
25. Custom ceiling
26. Compact Divisions CF door panels
27. Compact Divisions CF console lid
28. Complete redone interior from beige to black
29. Removed original seatbelts
30. Innovative wideband
31. KDM front door handle pockets
32. Clear courtesy light
33. LED room and map lights
33. Ilan's custom lighthing on HVAC on window switch
34. New black floor carpet
35. Profec II electronic boost controler
36. XDIAN emblem
The only Ausi tail lights, red hazard switch, and KDM triple dash gauge pod around plus the only hanging compass. I forgot manymods in this list but the pictures might tell. Sorry I couldn't get more pictures of the whole car during daylight in better spots.
1 - 3 of 3 Posts
Status
