1 - 6 of 6 Posts
For the past month or so I've been hearing a hum/growl coming from the front drivers side wheel and the pitch of the noise changes when I turn. I rotated my
tires today and couldn't feel any play. I did some research and it appears that the wheel bearing is bad. I'm thinking of buying a new hub assembly from a local
auto parts store, question is will I be able to remove the hub assembly myself? Are there special tools involved? I did the hubs on my girlfriends intrepid by
following this video http://www.youtube.com/watch?v=7-ZjbXoHvV0. Are Elantras similar? If not can someone point me to a tutorial on how to do it? Thanks.
I just got mines done not that long ago youll have to
1. Remove wheel
2. Remove calipers & rotor
3. Remove knuckle two bolts on top connected to strut & remove the bolt connected to ball joint which is under the knuckle & remove tie rod connected to knuckle onces all thats done youll just need to take out wheel hub & wheel bearing. If im wrong someone can correct me im a noob
KDM_STANCE_XD2
I try to help others
KDM_STANCE_XD2
I found a shop that will do the bearings for a reasonable price so I will just bring them the knuckle. I need help diagnosing which side. When I am driving straight, the whirring/howling noise is loud, when I turn RIGHT it goes away, when I turn LEFT it stays constant. From what I understand that means the bearing the the RIGHT side is the one going bad?
I can hear kind of whining noise at high speed from the passenger side front of my car. I followed your direction and turned the wheel, but I couldn't hear anything. So I checked the driver side front and I can hear ticking noise when I turn the wheel. I removed the wheel and checked the brake and suspension, but I couldn't find any abnormality. The ticking noise is not bad, but I am concerned. Can it be wheel bearing problem?
I had both front side wheel bearings replaced several years ago. At that time the grinding noise got louder as I increased speed. It was like jet engine.
1 - 6 of 6 Posts
