1 - 9 of 9 Posts
Enthusiast
My drivers side low beam blows after about 3 1/2 months
this is a reoccurring problem
I have never touch the bulb and have installed it according to instructions.:confused:
Are you turning the lights off when before you turn off the car or are you just turning off the car and letting the light turn off and come on automatically? That has seemed to cause them to burn out faster in the past.
LikeItLoud
It didn't ever seem to matter how I turned them off or installed them.
The only solution for me was to get HID's. You definitely won't regret it.
me too, drivers side only. passenger side is still factory. i just had the drivers replaced about 4 months ago and it just went out the other day.
The Amandamyster
my escort use to do that constantly until i finally got it looked at. drivers side as well. there was a wire that shorted out and was causing the bulb to overheat.
Super Moderator
Check out the bulb socket, as well as make sure that moisture is not getting into the housing causing the bulb to blow.
Enthusiast
Discussion Starter #9
I had it checked the constant blowing was caused by the lens vibrating so now im switching to 20 k hid's
1 - 9 of 9 Posts
