I am installing the factory foglight switch in my GLS. I got the switch worikng just fine, but I also want the foglight indicator to work. I found the wire leading to the bulb in the cluster, but webtech doesn't make it clear weather that wire wants 12 volts, or a ground to illuminate. If all it needs is a ground, then I can use the same wire from the multi-funciton switch right?
