1 - 2 of 2 Posts
04 GLS - Low, Slow, Angry
Well, I recently put in a new clutch kit, two axles, steering knuckle, hub, speed sensor, and passenger tie rod (outer) end...Now the drivers outer end is toast...It had a smidge of play and I knew it wouldnt last forever but it hasnt been 5000 miles...Probably 3000...
But thats not it, My cars been acting pretty foul lately...(do alternators make a tick noise when the brushes, etc wear out? If not, I've got engine problems again) Its had a tick, Laggy in the "get-up" now and then...I go to start moving, it hesitates, then takes off...its almost whip-lash worthy...I need to do massive body work...It constantly eats tires...Did even when the tie rod ends were good...Its just...been a bad year.
1 - 2 of 2 Posts
