It's a hilarious site with all the products they have.
More seriously, I don't know but I just learned that the hazard flasher and the turn signal flashers are different. (The turn signal's flash rate depends on load so you know when a bulb is out, the hazard flasher's rate is constant no matter how many bulbs are out). So it could be the turn signal flasher, or its power circuit. If it fixes itself after a while then I guess the fuse is fine.
Both the flasher and hazard relays are behind the interior fuse box, pretty close to the clutch pedal.
HmaService.com, ETM, Body Electrical System, Wiring, Main Harness, View B, connectors M38 and M39.
